Brand: Kitchen Aid Model Number: KDTE334GPS0 Main Symptom: Water leak What happens & when: All the time
I have a Kitchen Aid dishwasher, model KDTE334GPS0, that started leaking around the grommet that fits on the diverter motor/valve drive shaft. I replaced the grommet, which did not stop the leak. I then replace the diverter motor/valve and used another new grommet. This alleviated 99.9% of the leak, however it still drips water on occasion. What do I need to do to permanently fix the leak without having to replace the dishwasher? Thanks.
You’ll need to replace the sump and motor assembly W11178672 as a whole. Whirlpool officially discontinued that grommet a long time ago as an individually serviceable part and the only way to get it is with the above assembly, if you ordered the grommet by itself from somewhere then it isn’t going to be an OEM part.
