Water is leaking into the bottom freezer drawer when the ice maker is turned on
Brand:LG refrigerator
Model Number: LFC23760ST
Main Symptom: water leaking into bottom freezer compartment with ice maker on
What happens & when: only leaks water when the ice maker is turned on
Are there ice circles hanging off the icemaker? if so, there is either too much water going in the icemaker and it is overflowing, (replace the inlet valve), or the fill tube is missing the icemaker and it is out of position.
NO Ice maker working correctly. Water leaks down the back of the freezer compartment, slowly. Only leaks when ice maker is turned on
