Water flows from water dispenser and ice cube filler at same time
Brand: Frigidaire
Model Number:LFSS2612TPO
Main Symptoms; when getting drinking water, water flows from both the icemaker fill and drinking water spout
What happens & when: whenever depressing drinking water lever
Parts or tests already tried: replaced refrigerator water valve and filter
You will need the Frigidaire diode kit #5303918287.
When this diode fails activating the dispenser can cause water to come out of both the dispenser and ice maker fill tube. This is a OEM Frigidaire replacement part.
Great news, I think. is it an easy thing to replace this diode ? it would seem to me that if the door needs to be opened up, is not an easy thing to accomplish. Yes???
