Thanks for the information! On your Kenmore refrigerator, model 253.5470340A, a leaking water filter canister could be caused by a damaged filter seal, a cracked filter housing, or a problem with the water line connections.
Before replacing anything, let’s narrow down where the water is coming from.
1. Check the water filter. Shut off the refrigerator’s water supply, remove the filter, and inspect its rubber O-rings for damage, twisting, or missing seals. Also check that the filter is installed correctly and fully seated.
2. Inspect the filter housing. Look closely for hairline cracks in the plastic canister, especially around the threaded or sealing surfaces. Even a small crack can leak when the water system is pressurized.
3. Check the water line connections. If the water is coming from the top or back of the housing, inspect the tubing and fittings for loose connections or damage.
4. Check the filter itself. If the leak started after replacing the water filter, the replacement filter may be defective or may not be sealing correctly.
If the plastic housing is cracked or the sealing surface is damaged, the filter housing assembly will generally need to be replaced.
I have two quick questions:
- Is the water leaking directly from the filter canister itself, or from where the filter connects to the housing?
- Does it leak continuously, or only when you dispense water or the ice maker fills?
Those details will help us determine whether you’re dealing with a filter problem, a damaged seal, or a failed filter housing before purchasing another part.
In the meantime, I’d recommend leaving the refrigerator’s water supply turned off to prevent additional leaking.
