Washing machine tub overflows, won't stop filling with water even though I replaced the inlet valve
Brand: Whirlpool
Model Number:LSN2000LW0
Main Symptom: Washing machine still overflows even though I ordered and replaced the intake valve from your co, but at least I can manually turn the machine off and flow stops. Prior to that I had to turn off the main water supply at the wall to stop the water from flowing.
What happens & when: If I don’t manually turn off and stop the cycle as the tub is filling with water it will overflow.
Hi have you tried replacing the Washer Water-Level Pressure Switch W10339326 ?
Also, make sure the hose isn’t kinked or pinched anywhere. I’d blow through the hose as well to clear out any debris that may be stuck inside and preventing the pressure switch from reading the water level correctly.
