washer wont fill
The machine will not fill. I replaced the lid switch thinking this was the problem, as the machine would lock and unlock repeatedly. Tested the fill valve and show there is continuity
Based on your description of the problems I think the main control unit is at fault. Try replacing it and see if that fixes things. If you buy from this site and the new part does not fix the problem you can return it. See the returns policy for details.
