Washer will spin, but not under load. I can stop it by hand (or with some wet clothes). Transmission, Clutch, Basket Drive, something else?
Brand: Whirlpool
Model Number: WTW5500SQ2
Main Symptom: Won’t spin under load.
**What happens & when:
Spins when empty, but not when full of wet clothes. I can stop the basket by hand when spinning empty at full speed (with the lid switch jumpered and the cover off, I know…). There was a faint burning smell when trying to do the spin with wet clothes still in the machine (before I tore it apart). The motor seems to be struggling to get the basket up to full speed for the spin even when empty.
The motor runs, but I’m not sure how to check it beyond that.
The Motor Coupling is fine (all 6 teeth on both plastic parts and the rubber bit in between).
The splines and dogs/cam on the agitator and transmission shaft are fine.
The drive block looks good with clean notches and the tabs set in them.
[Sorry if some of this is irrelevant, I’m still trying to understand how this all works.]
With the transmission removed from the machine:
When I grab onto the transmission shaft and turn the motor coupling (HERE and HERE in the first photo below), I can manually force the drive to turn while keeping the shaft from rotating. It feels like it’s camming back and forth inside the transmission when I do this going counter-clockwise and there is some resistance, but not enough that I can’t overcome it.
When I grab the outside of the clutch body and turn the motor coupling at the bottom of the transmission clockwise, I can’t stop the clutch body from turning (same photo, but not marked).
When I grab the outside of the clutch body and the spring/brake inside it, I can spin the brake around inside the clutch body by hand without using much force. (3rd photo)
I can also rotate the drive basket brake by hand (2nd photo below with the big plastic cam).
With the transmission mounted:
Turning the motor coupling on the transmission by hand clockwise becomes very difficult after it locks in. Going counter-clockwise (agitation) is easy, even after the shaft starts agitating.
I’ve included photos of the bottom view of the Basket drive and the top of the Clutch. There was quite a bit of clutch/break dust on top of the transmission, which I cleaned off before taking this photo.
Any ideas on what the problem is or what next steps I need to take to pinpoint the faulty part is much appreciated.
I searched through old posts and found one that looked like it covered this but critical links in it were dead (edit: I found one of them and am trying to understand what it says…).
It seems like maybe the clutch is the issue, but I really don’t know, and would like to rule anything else out.
Thank you,
Error Code (if any): N/A - this is an analog unit. No codes. No brain.
Parts or tests already tried: Motor, Motor Coupling, Drive Block, Lid Switch, Splines on drive shaft and inside agitator, agitator cam and dogs.
Judging by your description and seeing the amount of grease on the top of the clutch f
linger ring, I’d say you need to replace the clutch assembly (Whirlpool 285785 Washer Clutch Assembly | Genuine OEM Part)
OK. Thanks for your help. I’ll order one then.
For what it’s worth, as a test/temporary fix this morning, I sanded the surfaces of the clutch pads enough to remove some of the gloss and rust from them, put the machine back together and ran a small load. It ran through the cycles, including the spins. I did not smell any burning and the load clearly got up to full speed with two pairs of jeans and a few small things in the wash.
Thanks again. I just installed the new clutch kit and everything works great. That old clutch was definitely slipping.
