Brand: Sears Model Number: 417.41142000 Main Symptom: Tub occasionally fills with water What happens & when: After a wash cycle is completed, the tub will occasionally slowly fill with water. After a couple of days, I can find 2-3 inches of water in the tub. Emptying the water and then running another wash cycle generally resolves the issue for a while. This happens no more than every few months, so it is not a consistent issue.
Error Code (if any): none
Parts or tests already tried: none
Photos / video link: n/a
Excessive water pressure making it difficult for the valve to fully close.
One possible test you can try is unplugging the unit after each wash cycle when it is not in use. If the issue persists while the unit is unplugged, I would suspect a water valve issue, as the valve should remain mechanically closed without power.
Hopefully one of these possibilities helps resolve the issue. If not, please feel free to reach out to us again, and we’ll be happy to continue troubleshooting with you.
