my washer starts to fill but then stops in about 15 seconds, the timer is good, the water level switch is good. I am not sure what it is?
can any one help.
can any one help.
[quote=richie33;520690]my washer starts to fill but then stops in about 15 seconds, the timer is good, the water level switch is good. I am not sure what it is?
the hose is clear
can any one help.
The gasket/assy brake is broken. This is a protection for your motherboard not to fry when there is a leak in your dishwasher. We have a samsung and it is under warrenty therefore recieved the parts to repair for free. For our samsung its a clear plastic case on the left side of the dishwasher. If you are trying to fix this on your own go ahead and order the replacement part and replace it. Its easy.
Hope that helps!
