Brand: GE
Model Number: gtw465asn2ww
Main Symptom: water does not fill properly
What happens & when: water starts and stops
Brand: GE
It would be recommended to get the tech sheet from inside the unit and put it into service diagnostic mode. While in service diagnostics, check to see if there are any error codes. If there are error codes, it would lead you to what may be going on.
