Washer not spinning
PLS HELP..MY WASHER NOT SPINNING BUT I HEARD THE MOTOR WORKING.IT FILL WATER . IS IT POSSIBLE THE AGITATOR NOT WORKING..OR CLUTCH NOT WORKS, OR SOME WHERE..WHEN I TURN THE KNOB CONTROL TO SPINNER ..THE AGITATOR NOT SPINNING ..BUT I HEARD THE MOTOR WORKING ..HELP:confused:
Sounds like your coupler broke.
Here’s the breakdown of your unit. Model LSR8233EQ1
The coupler is located between the pump & motor.
Part- [COLOR=#0000ff]Motor coupling (for direct drive washers)[/COLOR]
Hope this helps
Nat
My Washer Not Spinning..agitator Not Working.motor Works .it Fills Up Water,when I Set My Knob To Spin I Only Heard Motor Working..i Dunno Where To Trouble Shoot First..is It Possible The Clutch,brake,agitator Switch.or Somewhere..pls Help
As stated before.
[quote=libertyappl;50970]Sounds like your coupler broke.
Hope this helps
Nat[/quote]
[QUOTE=libertyappl;50970]Sounds like your coupler broke.
Hope this helps
Nat[/QUOTE]
my question now how can i remove the coupler of my washer. and said bet. the pump and motor..is that kind of hard and complicated.,is another way to make it simple to take and replace a new coupler..can you simplify and explain it brief how to dig it..is that under nit or in the very bottom of my washer
Go to www.applianceaid.com for info.
