Hi, I’ve checked the water inlet valve and the float valve and both are good. However, the water inlet valve does not get any voltage. I tested it two ways. First by removing the two wire to it and used a lamp cord with connectors to see if water comes out. I also tested it with my meter attached and started the washer and no voltage ever reached the valve? I am not sure where to go from here?
Thanks in advance,
