Washer fills with water by itself
i went out of town for a few days. came back went to do laundry and opened my front loader washer and water gushed out. it filled up by itself while i was gone. what you cause this? i have never heard of such a thing. please help
Most likely the water inlet valve stuck open. The solution is to replace the water inlet valve.
For more accurate advise and the right part number I need the complete model number of the washer.
it has not done it again can it be an intermitten problem
It could never come back, it could happen again next time you’ll be out of town.
Well, if you want to try your luck…
[quote=Gene;18724]It could never come back, it could happen again next time you’ll be out of town.
Gene.[/quote]
I don’t want to take a chance…I would like information on the part that will keep my unit from filling with water all the time. Mine does it all the time. My machine is a duet…Model number GHW9100LW2…
inlet valve is where your water hoses hook. See part here Replacement parts for WHIRLPOOL GHW9100LW2 | AppliancePartsPros.com in the control panel diagram parts list.
I also have the same problem. I have a Kenmore Elite 110.44836301 . What part do I need. Thanks
[QUOTE=rick c;84683]I also have the same problem. I have a Kenmore Elite 110.44836301 . What part do I need. Thanks[/QUOTE]
Here’s your water inlet valve to replace if yours is leaking. 110.44836200
Frigidare front-load washer Model 7088 FAFW3801LW
WHAT PART IS NEEDED?
