Washer board displays cycle and timer but won’t start and then shuts off
Brand: GE
Model Number:GFW550SSN5WW
Main Symptom: machine display works but won’t start any cycle
What happens & when: the Display allows for selection of cycle but once the start button is pressed the washing cycle will not engage and then after 10 - 15 seconds the display shuts off.
Would this be a new control board issue? Or would it be a door lock issue. When running diagnostics no code or issue comes up.
Error Code (if any):None
Have you run the component tests in diagnostic mode? Door lock and drain pump working?
