Wash Light On, Will Not Start
Will not start or function. Wash light constantly ‘ON’. Have tried power ‘OFF & ON’ with no effect. Where should I begin to troubleshoot?
Thank you, BOBALOO
Replacement parts for FRG FDB1051REB1 | AppliancePartsPros.com
Here is a tech sheet and a service manual. Service manual not exact but should be close.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154547901.pdf
http://www.frigidaire.com/tip/servicecd/Content/Dishwashers/5995436341_Dishwasher%20Precision%20Select%20Models.pdf
When you say on/off did you shut the breaker off for a couple hours.
If not try that.
Try any diagnostice in the manual
Open up the door and check the connectors.
