Viking VCSB5483SS: Defrost works but upper-left evaporator retains ice
Brand: Viking
Model Number: VCSB5483SS
Main Symptom: Heavy Ice Accumulation on upper left portion of evaporator
What happens & when: Freezer cools properly and defrost cycle works properly with the exception of that it doesn’t clear localized ice/frost in upper left corner of evaporator and this accumulates over time to the point that it blocks the evaporator fan.
Parts or tests already tried: Forced defrost, terminator resistance, evaporator resistance
Full detail:
I’m troubleshooting a recurring localized evaporator icing issue on a Viking VCSB5483SS built-in refrigerator/freezer and would appreciate input from anyone familiar with this Viking platform.
The freezer cools normally and maintains 0°F, and the defrost system is clearly operating. However, we have now observed multiple defrost cycles where the center, right side and lower-left portion of the evaporator clear substantially or completely, while the upper-left portion retains frost/ice. That residual ice survives into the next refrigeration cycle and appears to be where the larger ice accumulation we’ve experienced over time begins.
Here is what I have established so far:
• Freezer maintains its 0°F setpoint normally.
• Evaporator develops frost across essentially its full width during normal cooling, although somewhat heavier on the left.
• Defrost heater is functioning and previously measured approximately 29 ohms.
• During an observed defrost cycle, most of the evaporator cleared, including the lower-left area.
• The upper-left portion did not completely clear before defrost ended.
• Afterward, the freezer returned to 0°F normally, but residual ice remained in that upper-left area.
• The evaporator drain is completely clear and drains freely into the condensate pan.
The heater is a continuous element running down the left side, across the bottom and up the right side. Interestingly, the boundary where ice remains on the upper left appears to be approximately where the active portion of the heater ends and its electrical lead begins. The evaporator clears quite well below that point but not above it.
I’m therefore trying to determine whether the defrost cycle may be terminating before enough heat reaches the upper-left portion of the evaporator.
Defrost terminator location
The terminator is currently clipped to the exposed copper refrigerant tubing immediately above the upper-left corner of the evaporator. There are two adjacent copper tubes there, one larger diameter and one smaller.
One complication is that I previously removed the terminator to bench-test it at temperature and then reinstalled it. At the time I did not realize its precise position might be important, so I cannot guarantee that I returned it to its exact original location.
Does anyone know the factory-specified installation location for the terminator on this Viking platform?
Specifically:
  1. Should it be clipped to the larger or smaller copper tube?
  2. Exactly where along that tube should it be located relative to the top of the evaporator?
  3. Is the exposed copper tubing above the evaporator correct, or should it be attached directly to tubing within/against the evaporator?
  4. Does anyone have a service photo, bulletin or intact-unit photo showing its factory position?
The relevant part numbers I have identified are:
Evaporator: PM910206
Evaporator defrost heater: PJ910031
Original defrost terminator: PB910259
Superseding terminator: 058966-000
I’m also interested in opinions about the heater installation/geometry. Is it normal for the active portion of PJ910031 to begin below the top-left portion of the evaporator, or should the heater extend farther upward? The correlation between where the active heater ends and where residual ice remains is pretty striking.
Thanks in advance for any insight. I’m particularly interested in establishing the factory terminator and heater installation before replacing or repositioning parts.
Click here for related pictures: I don’t have an image of the evaporator when it was completely frozen over (seized up the fan) but these images show the evaporator after I completely defrosted it and then restarted it. One shows the visible part of the evaporator during normal operation and the other during the defrost cycle. These pictures were taken only 48 hours after the full defrost but you can already see the disproportionate accumulation on the left side.
Based on what you’ve observed, I would not replace the control board or evaporator at this point. This looks much more like a localized defrost-heat problem, and the fact that the defrost terminator was removed and its exact original location is uncertain makes its placement especially important.
I found Viking documentation for the same 48-inch SXS evaporator platform showing PM910206 evaporator, PJ910031 heater, and PB910259 defrost terminator together in the low-side assembly. Viking has since superseded PB910259 to 058966-000. All Viking Parts
The frustrating part is that the available Viking exploded view identifies the components but does not specify which of the two copper tubes the terminator clips onto or give an exact measurement for its position. So I would not claim that the large tube or small tube is correct without an intact-unit photo/service bulletin.
What your defrost pattern is telling us
Your 29-ohm heater reading is very reasonable for a 120-V heater—roughly 500 watts when energized. More importantly, you’ve actually watched it defrost. The center, right and lower-left clear while the same upper-left section remains frozen.
That pretty much rules out a simple “heater isn’t coming on” problem.
The location of that remaining ice is the biggest clue. PJ910031 is the correct SXS evaporator heater for this Viking platform, and Viking parts documentation confirms its use with PM910206. All Viking Parts
If the resistance-heating portion physically stops below that upper-left section, then some amount of delayed melting there may be normal. But it shouldn’t repeatedly leave enough ice behind to accumulate cycle after cycle until the fan is obstructed.
I would concentrate on the terminator first
The terminator isn’t measuring the average evaporator temperature. It reacts to the temperature where it is physically clamped.
So moving it even a few inches—or putting it on a different diameter tube—can change when it opens.
If it is currently sitting on tubing that warms faster than its original mounting point, this sequence makes perfect sense:
Defrost starts → heater operates → lower/center evaporator clears → terminator’s tube warms → terminator opens → heater shuts off → upper-left corner hasn’t finished melting.
Then the compressor restarts and that remaining moisture/ice becomes the seed for the next accumulation.
That fits your observations unusually well.
One test would prove it
I would completely defrost the evaporator manually so you’re starting with zero residual ice. Then allow it to operate long enough to develop a normal frost pattern.
On the next forced defrost, watch three things simultaneously:
  1. Heater voltage/current — determine exactly when PJ910031 loses power.
  2. Terminator continuity — determine whether the terminator opening is what actually ends heater operation.
  3. Upper-left ice — see how much remains at the exact moment the terminator opens.
If the terminator opens while that upper-left section is still substantially iced, you’ve found the mechanism.
An even better diagnostic is to attach temperature probes to the terminator mounting tube and the iced upper-left evaporator tubing. If the terminator location gets warm enough to open while the upper-left evaporator is still below freezing, its mounting location becomes highly suspect.
I would not bypass the terminator to extend defrost, other than following an official Viking diagnostic procedure. It’s a safety device.
Heater geometry
I also would not reposition PJ910031 just because the upper portion isn’t directly covered by it. The available Viking documentation shows PJ910031 as the specified heater for this evaporator family, and current Viking parts sources still identify it as the SXS evaporator heater. iFixit
However, inspect it closely for two things: make sure the heater is fully seated in its factory clips against the evaporator, and make sure it hasn’t sagged downward or been installed with the upper bends lower than intended. Viking’s low-side parts breakdown actually identifies dedicated evaporator-heater clips 10428101, which reinforces that its physical positioning matters. All Viking Parts
My order of attack
I would not buy anything yet.
First, establish the correct PB910259/058966-000 mounting position. Second, verify the heater is sitting correctly in its clips. Third, observe exactly what event shuts the heater off while that upper-left ice remains.
If the terminator is opening first, I’d correct its location before replacing it. If it’s correctly located but opening prematurely, then 058966-000 becomes the logical replacement. Viking specifically lists 058966-000 as the replacement for PB910259/10442407. All Viking Parts
If you can post a clear photo of the entire upper-left corner of the evaporator showing the two copper tubes, present terminator position, and the top of PJ910031, I can look at the actual tubing layout. That may let us determine which tube is the evaporator outlet/suction line versus the other line and make a much better call on where that terminator belongs.
