Brand: Viking
Model Number: VGSS300-4BD-SS
Main Symptom: no spark after new spark module replacement
What happens & when: All of a sudden the stove top spark failed when trying to light an unused burner (while other burners were being used). The spark (to all 4 burners) failed to be restored even after replacing the spark module with part number PA020041. I have confirmed to have 120V going to the replaced (and original) spark module. However, turning any of the burner knobs does not generate a clicking noise. Is there something else to ohm out on the spark module to eliminate/identify it being bad or is there another part that could be causing the lack of clicking and spark? Also wanted to add all the burners will light if I were to use an external flame and the flame doesn’t appeared to be decreased.
Thanks.
Parts or tests already tried: PA020041 spark module
