The upper spray arm doesn’t spin and I can’t figure out how to remove it for cleaning. Also, if there is a filter screen in the channel that delivers water to the upper spray arm I need direction for accessing it.
Edit I may have found the problem, which I read on another post. I don’t think enough water is getting in washer. The water doesn’t cover the heating element which understand it should. The faucet is turned all the way on, so I guess that means that the valve in the machine needs replacing. Any other possibilities?
Clean the screen in the inlet valve, MAKE SURE to re-install the screen correctly when done!!!
Thanks. I’ll try it in the morning.
Our washing machine is working, again, but I had to call a repairman. I couldn’t figure out how to get to the filter screen and he had a bit of difficulty, too.. When he got to it, he found the food chopper had broken off the pump impeller shaft. The filter screen was really clogged, so I cleaned it, the repairman reassembled everything and now the machine has good water pressure. I also learned how to get to the filter screen from inside the machine. We’ll use the dishwasher without the food chopper as long as it keeps running.
Just make SURE not to put a bunch of FOOD in the DISHWASHER, It will work FOREVER, If you use a little care with rinsing the dishes before washing them. GLAD you got it going!!!
