I have a Whirlpool Quiet Partner III Dishwasher (2-3 y.o) that worked this morning. This evening when the door was closed it did not activate nor does the control panel lights illuminate. Checked the breaker, receptacle and power cord plug. All found intact.
Is there a reset button? Any ideas why no power? Btw everything else in the kitchen is powered.
If you are sure it has power, then the first thing I would check would be the thermal fuse (Item 6 in the “Control parts” section). These seem to go on a regular basis hence they are now in a kit with the harness.
Next would be the door switches.[/quote]
Thank you very much.
Where do you find the “Control parts” section? I’ve looked through the owner’s use and care guide manual, is that a repair manual you’ve referenced?
