Unable to control freezer or refrigerator temperature after new mother board installed
Brand:GE
Model Number:GE PSS26PSWA SS
Main Symptom:Can’t control temperatures
Parts or tests already tried:Unable to control freezer or refrigerator temperature after new mother board installed. Power supply failed on old mother board (bad caps). With the new mother board all other functions other than temp issues are now OK. Front panel accepts and displays inputed freezer and refrigerator temp settings and current freezer and refrigerator temps displayed are always correct, as measured in the compartments. However, freezer remains fixed at measured 5 deg and refrigerator at 42 deg. regardless of panel settings.
I am unable to locate that model number can you verify it and possibly send in a picture of your model label
As requested:
Thanks for the photos and the detailed explanation. That helps narrow things down quite a bit.
On your GE PSS26PSWA SS, the refrigerator is maintaining approximately 5°F in the freezer and 42°F in the fresh-food compartment, regardless of the temperature settings.
Since the display shows accurate temperatures and accepts your adjustments, I wouldn’t replace the display panel just yet.
Your self-diagnostic screen shows:
  • Main Board Software: 41x
  • HMI Board Software: 10J
  • EEPROM Test Status: Done
The EEPROM test showing “Done” doesn’t necessarily mean the entire control system is working correctly. It also doesn’t confirm that the replacement motherboard is properly configured for your refrigerator.
My first suspicion is the replacement motherboard or its compatibility with your model, especially since the temperature-control issue began after replacing the original board.
Here’s what I’d check next.
1. Verify the motherboard part number. Check the number printed on the replacement board or its packaging. We need to confirm it’s the correct replacement for PSS26PSWASS and whether any installation instructions or configuration steps were required.
2. Try a temperature-change test. Set the freezer to 0°F and refrigerator to 37°F. Allow 24 hours with normal door use, then check both compartments with a thermometer. This will help establish whether the controls are responding.
3. Check the evaporator fan and airflow. Make sure the freezer fan is running and cold air is reaching the refrigerator compartment. A restricted damper or weak airflow can keep the refrigerator too warm.
4. Check the temperature sensors if necessary. This model uses thermistors to communicate compartment temperatures to the control board. Even with accurate displayed readings, we may need to check their resistance and wiring.
Repair Clinic+2
I have two questions before we go further:
  • What is the exact part number of the new motherboard?
  • When you change the freezer setting from 5°F to 0°F, does the compressor continue running, or does it shut off even though the freezer hasn’t reached the new setting?
Those answers should help us determine whether the new board is failing to respond to the temperature settings or whether we’re dealing with a separate cooling issue.
In an attempt to expedite this issue I repaired my old mother board and reinstalled it. The old board worked fine although the temperature control problem persisted. I checked the thermisters and found one on the fresh food evap that was way out of tolerance as indicated by the Unit Service Manual.I’ll do somemore checks as time permits. Thanks for your assistance.
