Tub tilting to the left after moving
After recently moving into a new residence, I went make sure the machine was level and noticed that the tub is tilting to the left. A repair person was supposed to come and look at it 3 hours ago but hasn’t shown up. I understand that it could just be a spring but I have no idea to take it apart to check. Does anyone know of any videos or instructions on how to take this apart to check the springs? Is there anything else I should look at that could be making the tub tilt?
Thank you for any help you can give me.
A quick look under the bottom of the machine. Remove the hoses unplug power, pull away from the wall and tilt back so that you can peek underneath. If the tub is tilting to the left likely the spring on the right side is off…
