Found terminals burnt on motor. What next?
tub not turning, found burnt terminals on motor. What steps should we take next?
Wire terminals or motor terminals?
What is the complete model number of the dryer?
[SIZE=“4”]Gene[/SIZE] I did not notice this was a duplicate so will just add mine to yours and then will mark the other one.
A model number may help others help you.
Terminal appears to be burnt and the tub is not turning like it should.
A better description of the problem would also help.
What do you mean by "Terminal?
What is burnt?
How is it not turning as it should?
etc.
etc.
Read more: http://forum.appliancepartspros.com/dryer-repair/117566-dryer.html#ixzz0xXVt9tUG
