Brand: Kenmore Model Number: 25354623403 Side By Side Main Symptom: Evaporator is Icing and Refrigerator side is warmer than normal What happens & when:
Parts or tests already tried: I replaced the defrost thermostat and the evaporator fan motor
Is the evaporator icing up along the entire evaporator or is it only in a specific section? Also, what temperature is the freezer when measured checked by leaving a thermometer in between two bags of veggies or other items for about 20 minutes?
The defrost heater would need to be tested for resistance when the appliance power cord is unplugged. It should measure 30 Ohms of resistance, plus or minus 2 Ohms. If it does not, the heater would need to be replaced. If it measures good, the adaptive defrost control is the cause of failure. Here are links to each part.
