The start button on the touchpad does not work. How difficult is it to replace it?
Replacement parts for WHIRLPOOL KUDS01FKSS0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208524517.pdf
And this should help you get to it
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Your problem is either the touchpad or the control board.
The usual way to troubleshoot this is to check the touchpad with a meter, if it checks out OK go with the control board first. Still a bit of a crap shoot but your odds of getting the correct part first try are better.
I would try the connector cleaning as you may not need any parts.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
