Touch pad troubles
The touch pad is very erratic on our Maytag quiet series 300 dishwasher. Some times it works sometimes it does not. Often you can touch the cycle pads and only 2 of the four choices lights up and the start pad won’t light up or work. Does the whole touch pad need replacing? Can it be replaced? Is this a common problem with these machines. It is currently working after not working for 2 days. I really appreciate any info on this problem. Thanks
A Model Number may help others help you.
Could be the control board or the keypad is going but I would try the following first. I am assuming this unit has a seperate control board and keypad as this is the norm.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
