The top two washer racks have no water dispersing while the bottom does. I took the wash assembly apart and there is nothing pluging it. The bottom washer is working and it connects to the top washer. I know there is no water coming out cause i set the washer rack in a fixed position and turn dishwasher on, in rinse cycle. After i heard the water cycle start i opened the door and the upper washer was still in the same position. Maybe the pressure is not enough? Any help would be great.
Janick,
The first thing I would do is check the chopper (#6 on the diagram).
You can find more useful information in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS02FRSS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
[quote=Gene;476519]Janick,
Gene.[/quote]
Thanks Gene - how do i get to the chopper. I took everything off and im at #4 in the diagram (looking at sump housing). Do i need to do undereath the dishwasher. I think i’m missing a step
Just click on the link from the previous reply for instructions.
[quote=Gene;477065]Just click on the link from the previous reply for instructions.
Gene.[/quote]
Believe it or not i did.
Could you please tell me if the chopper is on the sum housing (#4) or is it in the accumulator assembly (#1). For some reason i can’t find the protector (#8) therefor cany find the chopper. I’m having problems finding it even while I’m looking at the diagram
It is inside the sump housing under the accumulator assembly. The accumulator assembly has to be removed.
