The glasses and cups in the top rack do not wash They seem to get wet but it appears no pressure is on the spinner Water level seem correct.
Remove the pump cover and the inlet protector.
Check the chopper for clogs.
check water level is correct .will not wash properly with low water level. if not could be problem with circulating pump motor . also check for debris in pump motor down to impellor
