Top Load washer won't complete drain and spin cycle with large loads
Brand: Whirlpool
Model Number: WTW4616FW2
Main Symptom: Won’t complete drain and spin cycle with large loads
What happens & when: Washer completes cycles until the final drain and spin with larger loads. When attempt to activate the cycle, the washer starts a new wash cycle. I have unplugged and turned off the breaker for an hour or more to reset - no effect. It will complete all the cycles with smaller loads.
If the washer is placed into a Fault Code Display mode, any error codes that appear can help to identify what might be going on. With the washer LEDs off, rotate the cycle knob in this pattern with a .5 second pause between rotations: counterclockwise 1 click, clockwise 1 click, clockwise 1 click, clockwise 1 click, counterclockwise 1 click, clockwise 1 click. All of the LEDs should illuminate upon a successful entry. Rotate the cycle knob clockwise 1 click and the LED done should be the only one illuminated. With the done LED illuminated, press start. The status LEDs should flash on and off. Rotate the cycle knob clockwise 1 click and this should be the most recent error code identified where the LEDs will flash in a specific pattern pause, then flash another pattern. It will repeat this. What is the first flash pattern and the second flash pattern? Also, if you rotate the cycle knob clockwise 1 more click, what shows up for the second recognized error if there are any? The power cord can be unplugged to exit this mode without deleting the error codes in case they may need to be referenced again.
