Toddlers stood on the door
My toddler and one of his friends stood on the door and bent it down…the dishwasher works fine. The door opens and closes, it is slightly heavier then before and will not spring shut. However, the springs look fine…but when you one the door it is angled down towards the ground and then when you pull the bottom rank out on the door, it practically flies out on to the floor if you are not careful! This never happened before. What should I do? Can I fix it? Kids…gotta love 'em!
You have to check the door hinges and the door frame. The model number you posted does not come up. Verify and repost it.
