Timer wont advance and dryer wont heat
Hi, My dryer timer doen not advance in Automatic heat mode. The timer does advance in timed drying but in either mode there is no heat. I tested the Thermal fuse and Cycling Thermostat for continuity. The thermal fuse is good and the Cycling thermostat has continuity across 2 termainals but not the other two, which leads to my main question. I saw the list of 5 items to check for continuity but how do I know which terminals or wires are supposed to have continuity when there are more than 2 on a part? or can you determine from the information above which part I need to replace. Thanks, Anthony
Do your clothes dry completely on timed dry, or do you have to run it again to get dry clothes?
The clothes are not even the slightest bit dry…in my wifes words.
