Thermador DWHD630GCM/63 dishwasher runs drain pump with door open and does not start cycle
Brand: Thermador
Model Number: DWHD630GCM/63
Main Symptom: Won’t start wash cycle
When powering on the dishwasher with the Auto wash cycle selected, it sounds like the drain pump is running even when the door is still open. It continues to run the pump once the door is closed, but the wash cycle never begins. Reopening the door is no change - the pump continues to run. Only turning the power off will stop the pump from running. I’ve tried a cancel/reset by holding the Auto and Normal cycle buttons at the same time and this just resets the LED timer indicator to zero. The pump continues to run.
I’ve worked through the Max Parts Assistant chat on the AppliancePartsPro.com website and it suggested that the door lock switch (Bosch OEM 00187205) may be failing.
I also spoke with customer support and they suggested there could also be a problem with the dishwasher float switch (Bosch OEM 00165256). They suggested posting on this forum to get a more accurate technical answer.
I’d like to get the correct part to solve this problem. How can I troubleshoot this issue further to find out exactly which part to order?
This unit has a base at the bottom. Take off the kickplate and pull out the water valve, then using a towel or cloth, slide it in and see if there is water in the base. If there is then replace the water valve on the unit. The unit has a float that if it senses water in the base pan it will continuously run the drain pump.
Ed_C,
Thank you for your reply to my inquiry. That was exactly what I needed to steer me in the right direction. The water inlet valve must have had a slow leak into the bottom case that I think became more pronounced after I opened things up and started poking around. The float was definitely triggering the sensor. The corresponding pump running while the door was open with the dishwasher powered on made sense now. I’ve since replaced the water inlet valve, ensured there were no leaks after drying out the bottom case, and then successfully tested the dishwasher. All is good now. Learned a few things here… Thank you so much!
Part used to fix this: Bosch Dishwasher Water Inlet Valve OEM Part (Part# 00607335)
