[QUOTE=viljef;85607]I have same problem but the display is totally black. Thermador has stopped making the display bd AP3382408. I took the board and out and tested the capacitors and they seemed to power up and release. I noted in the top left corner a burned out spot where a small light is located. Could this be my problem and if so can it be replaced. I see noway to access it or remove it. Thanks.[/QUOTE]
What is the complete model number of the oven?
