Just installed it and it will not drain water. Can anyone help.:mad:
If attached to a disposer did you remember to knock the plug out.
Here is a decent install sheet that is applicable to most units.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
