There is a internet youtube show Bens Appliances and Junk
Brand:Maytag
Model Number:mvwc415ew0
Main Symptom:wont spin automatically
What happens & when:going through normal cycle wont spin at automatic spin: but will spin if set to manual spin
Error Code (if any):something about control board
Parts or tests already tried:instead of letting it spin which it wont do in a regular cycle i turn dial to spin
during 1 of Bens repair videos he had same symptoms, he said he got his hands on a valve that was soldered onto the (control board that cost 300.00) and replaced only that valve and it fixed a couple of machines that he had… anybody know the name / part # and where to acquire one
Hi jimbean802,
I’m not sure which part you’re referring to or what it’s called, but I went ahead and attached a tech sheet to help diagnose your washer. It may also help identify the part you’re looking for. Once we know which part it is, I’ll be happy to help you find the correct replacement.
WTW5000DW-W10677676-Tech-Sheet.pdf (2.1 MB)
