[LEFT]Dear sir: I have a whirlpool quiet partner ll,model du1100xtps1 about 5 yrs old.It current works only on drain&cancel setting.The " normal" mode selection buttom and the “star” buttom are unresponsive.can you suggest the control panel or control board is bad? Thank you! [/LEFT]
Here are the parts
Replacement parts for WHIRLPOOL DU1100XTPS1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Do not know what button is the “star” button but if it is the start button, you will notice in the tech sheet that the start and normal buttons have P1-4 as a common.
I would check the keyboard as outlined in the tech sheet.
The normal way to trouble shoot is check the keypad if it is OK then replace the control board. Note this is still a bit of a crap shoot but it does give you better odds of ordering the correct part.
[COLOR=Red]
Try the following first.[/COLOR]
Unplug the unit
Open it up
Clean the edge connector.
