Brand: Whirlpool
Model Number: wfe320m0js3
Main Symptom: Connection
What happens & when: Not the same
Vivian87, it is common for the terminals to change positions as manufacturers revise their parts. Based on the image, the terminal position changed to where one would be on the thermal limiter block while the other is directly on the circular element housing. This is a very common design being produced these days and would not affect compatibility.
Thank you for the advice. I was able to work through it and it worked perfectly!!
