The flapper on the ice chute won't stay closed
Brand: Kitchenaid
Model Number: KSSC42QVS06
Main Symptom: Ice chute flapper will not seal causing water to drip
What happens & when: Once ice dispenses the door stays open unless I close it manually
Hi Derwoood, it sounds like the motor that operates the flapper is starting to go out and will most likely need to be replaced soon. I’ve attached the part number you’ll need for the replacement. Hope this helps! Whirlpool WPW10504458 Refrigerator Ice Dispenser Door Assembly | Genuine OEM Part / Whirlpool WPW10546285 Refrigerator Ice Door Motor And Bracket Assembly | Genuine OEM Part
Should I change the chute flapper (door) while I am at it? It looks like I need to remove the front stainless skin from the freezer door to access it…Is that correct? And if so any issues with removing the skin?
Yes, I’ve attached both part numbers. I would recommend replacing both at the same time. It’s better to do them together so you don’t have to go back in and replace the other one later.
What about the skin removal. Any issues with doing this & is that the correct way to access the part?
I’ve attached a video that should give you a general idea of what needs to be done and the steps involved with the repair. https://youtu.be/r9oJxxucSlo?si=g71oavlADRvvW0SI
