Temperature Sensor Error
I recently replaced the pump housing assy. when i replaced the assy and did a test run, an error code C7 (i believe), temperature sensor error, came up. I am pretty sure all the wires were connected correctly. I verified all the wires were connected. Unfortunately, i do not see anything online to indicate where the temp sensor is or where it is connected. Please let me know if there is a wiring diagram or a drawing of where this temp sensor is.
Thanks in advance,
Mr. Break It
The error corrected itself. All the wiring was correct.
