The Support Arm broke on my old Maytag. I received the part without any instructions. It looks simple enough, but I’m not sure what to do with the rubber seal that shipped with it. It might be obvious when I take it apart, but I thought maybe someone has dealt with it before. Thanks for any help!
CC16,
How’s about a part number for the part,
So we can give you a better idea of what to expect.
Thanks,
Yes the part number is WPL 12001229
CC16,
In your case you wont need the gasket/seal, just the support arm.
The gasket was included in the kit for older units, it was not needed on your unit, because there was a re design of the pump assembly and cover.
Thanks for your help!
You’re welcome,
If you need anything. Drop us a line
We’re here to help.
