Stumped
HAD A QUIET ARTNER II replaced control panel then thermal fuse got it up and running using reset keys now getting continuous blinking rinse only light what do I do! Spent major money on new board and fuse still no luck but for one half cycle.
Kingmarky,
You most likely have(had) a or several bad keypad(s).
[FONT=Swiss721BT-Black][LEFT]ERROR MESSAGES[/LEFT]
[/FONT][FONT=Swiss721BT-Black][SIZE=2][FONT=Swiss721BT-Black][SIZE=2][LEFT]STUCK KEY:[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][LEFT]If the control detects that a key is stuck in
the depressed position, dishwasher
operation will be suspended and the
control will flash the light for that key until
the condition is corrected. If a key without
a light is stuck/shorted or multiple keys are
stuck/shorted, the control will flash the[/LEFT]
Rinse cycle key light.
[FONT=Swiss721BT-Black][LEFT]RAPID ADVANCE SERVICE FEATURE AND
DIAGNOSTICS CYCLES [/FONT][FONT=Swiss721BT-Black][/LEFT]
[/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][LEFT]Pressing the following option keys in the sequence shown will either start
the Diagnostics Cycle or turn on the Rapid Advance feature for customer
selectable cycles:[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][LEFT]HI TEMP WASH [/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]AIR DRY [/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]HI TEMP WASH [/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][B][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]AIR DRY
  • or -[/LEFT]
    HI TEMP SCRUB/SCOUR [/B][/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]AIR DRY [/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]HI TEMP SCRUB/SCOUR [/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Times New Roman][SIZE=1]→ [/SIZE][/FONT][/SIZE][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1]AIR DRY[/SIZE][/FONT][/SIZE][/FONT]
    [B][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][FONT=Arial][SIZE=1][LEFT]If the above key sequence is entered with the dishwasher in Standby, the
    Diagnostics Cycle is started. The operator can advance the cycle, interval
    by interval, by pressing the Pots & Pans or Anti-Bacteria key.[/LEFT]
    [/SIZE][/FONT][/SIZE][/FONT][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]
    You could also try, disconnecting the touchpad ribbon, from the new control board, thoroughly clean the insertion end of the ribbon with alcohol, re insert the ribbon, properly and tightly, and try again, after you reset the control board.
Good Luck,
:slight_smile: :slight_smile: :slight_smile: [/B][/SIZE][/FONT][/SIZE][/FONT][/B][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
