Stuck on rinse only
Can select various cycles, but after starting, dishwasher reverts to rinse only. It runs the rinse cycle and stops without opening the soap tray. Would a loose wire do this or are we likely into a control board? Can you point me to disassembly and replacement instructions? Is there anything I should look at before ordering a control board? … Additionally, the dishwasher sits with its rinse only blinking. Power cycling it allows selection of other cycles, but shortly after starting it returns to display of rinse only light. Without power cycle, we cannot get it to light any other buttons. Could there be a short from leaning against the panel?
Replacement parts for MAYTAG MDBH955AWB | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/maytag_library/docs/16021814.pdf
http://www.servicematters.com/maytag_library/docs/16026393.pdf
[COLOR=Blue]Would a loose wire do this or are we likely into a control board?[/COLOR]
More likely a stuck key but I am not 100% sure on this
[COLOR=Blue]Can you point me to disassembly and replacement instructions?[/COLOR]
See above links
[COLOR=Blue]Is there anything I should look at before ordering a control board?[/COLOR]
With electronic parts usually if you order it you own it so is best to troubleshoot as far as possible.
Try running the diagnostics.
Sometimes just running them will clear an error.
Check the keypad pin outs (ribbon cable) with a meter (see tech sheet).
This is the normal way to troubleshoot these types of problems. If the keypad checks out OK then it is probably the control board that is shot. It is still a bit of a crap shoot but improves your odds of getting the correct part.
Try cleaning the connectors (see below)
[COLOR=Blue]Could there be a short from leaning against the panel?[/COLOR]
Pushing very hard on a switch could collapse it causing a problem but this is unlikely.
		 		 		 		[U][COLOR=Red]Connector Cleaning[/COLOR][/U]
Unplug the unit
Open it up
Clean the edge connector.
[COLOR=Red]Meter[/COLOR]
