Stuck button/error messages
My delay hours button is stuck on ..blinking.
when I go threw the suggestions from here and my tech papers for diagnostic , the only thing that changes is the “rinse only” button comes on and starts blinking along with the delay hours button. Turned breaker off, etc. Still nothing, and no other lights come on. Please suggest something!!
I was hoping there was an easier way, but from other posts I figured I would have to change the control panel. Just thought since mine was the delay hours button, it might of meant something else. Thank you for responding.
There may only be one other thing i can think of. If your unit has a control lock on it check your manual or look at the front and see if there’s a picture of a lock and it usually has you press 2 button simultaneously to lock and unlock the keypad. Good luck
I tried the sani-dry sequence and all of a sudden all my lights came on and the washer started washing. For about 3 minutes then stopped and back to the blinking delay hours button. I did order the control panel from this site but just wondering if this last episode still means the same problem?
(Control button not locked)
I tried the new control board that came in today and my diswasher worked for about 5 minutes and back to the blinking “delay hours” button!! I opened the door and closed it washed about another 3 minutes and back to the delay hours blinking. I’m frustrated. what can it be?
