Straight Wiring A Kenmore Dryer Motor
A friend of mine recently bought a new dryer and i took the old one apart and took the motor out (part # 3395654). I want to wire it up to run and use it like a small fan and possibly a small heater in my shop but i cant find a wiring diagram to figure out how to straight wire it so i can put a switch on and plug it straight in. Basically what i need to know is: There is a Blue wire, a purple wire, and a white/orange wire on the motor. There is a Black wire, Green wire, and a White wire on the power cord i’m connecting. Which wire should connect to where and which line should i put my switch in?
I hope the wiring diagram for a dryer with a such motor will help you.
Let’s see
