Stops spin/agitate relieved by belt reinstall
Brand:kenmore
Model Number:417.41142000
Main Symptom:ceases spin/agitate mid-cycle
What happens & when:removal of belt allows drum and motor to move freely and for cycle to continue, no play in motor shaft, without belt rub noise from tub and motor, in operation loud run from motor
For your Kenmore washer, model 417.41142000, the fact that the motor and drum turn freely with the belt removed, and the cycle continues without the belt, is a helpful clue. It suggests the motor may be struggling when it has to turn the weight of the drum, or there may be resistance in the drum assembly that isn’t obvious when turning it by hand.
I would check a few things before replacing the motor.
1. Check the drum bearings and pulley
Unplug the washer and leave the belt removed.
  • Spin the inner drum by hand. It should turn smoothly without grinding, scraping, or rumbling.
  • Grab the inner drum at the front and lift upward. Check for excessive movement or clunking.
  • Inspect the large rear drum pulley for wobbling, damage, or signs that it has been rubbing against the outer tub.
  • Check for anything caught between the inner and outer tubs.
A worn tub bearing can sometimes turn freely by hand but create excessive resistance under load.
2. Check the motor with the belt removed
Since you mentioned a loud rumbling noise coming from the motor, I would pay particular attention to the motor bearings.
With the washer unplugged:
  • Turn the motor shaft by hand and feel for roughness or binding.
  • Check for any side-to-side movement in the shaft.
  • Inspect the motor pulley for damage or looseness.
Even without noticeable shaft play, a motor bearing can still be worn.
3. Check the motor under load
If the drum and pulley check out, the motor becomes a stronger suspect.
A motor with a failing winding or internal problem may run normally without the belt but struggle or stop when the belt is installed.
Also inspect the motor wiring connections and look for signs of overheating.
If the motor stops during operation, determine whether it is overheating and shutting down on its internal thermal protector. Do not repeatedly restart an overheating motor.
Safety: Unplug the washer before inspecting or removing components. Avoid touching moving parts during operation.
My recommendation
Based on your description, I would concentrate on the motor bearings, tub bearings, and motor operation under load before replacing any parts.
One question that would help narrow this down:
When the belt is installed and the washer stops agitating or spinning, does the motor continue humming or making noise, or does it become completely silent?
That will help determine whether the motor is struggling against a mechanical load or losing power during the cycle.
When stopped, the motor makes no noise but the control continues to click. So far this has happened only on Spin. One thing that seems to say it isn’t the bearing is that there’s no play in the shaft.
Thanks for the update! That’s helpful information. Since the motor goes completely silent while the control continues clicking, and this has only happened during Spin, I’m leaning more toward a motor or motor control issue than a bad tub bearing.
You’re also correct that no play in the shaft is a good sign. However, a bearing can still be worn or binding without having noticeable play.
Here’s what I would check next on your Frigidaire 417.41142000:
1. Check the tub with the belt removed. Unplug the washer, remove the belt, and spin the large tub pulley by hand. It should turn smoothly without grinding, scraping, or tight spots. Listen carefully for any rough bearing noise.
2. Check the motor separately. With the belt removed, turn the motor pulley by hand. It should rotate smoothly. Since you previously mentioned the motor makes a loud running noise, I’d pay particular attention to roughness or resistance in the motor bearings.
3. Check whether the motor is overheating. If the washer stops spinning, disconnect power and carefully check whether the motor housing is unusually hot. A motor with failing windings or bearings can overheat and trip its internal thermal protector. When that happens, the motor goes silent even though the control continues trying to operate it.
4. Check the motor voltage. If the motor stops but the control continues clicking, checking whether the motor is still receiving the proper voltage can help separate a motor problem from a control or wiring problem. This is a live-voltage test, so use caution. The exact connections should be identified from the wiring diagram before testing.
Here’s what really catches my attention: You previously mentioned that removing the belt allows the motor and cycle to continue normally. That suggests the problem may occur when the motor is placed under a load. A weak motor, dragging tub bearing, or motor control problem could explain that behavior.
Before replacing anything, I’d like to know one thing:
When the washer stops spinning, if you leave it alone for 15–30 minutes, will it start spinning again without unplugging or resetting it?
That would be an important clue because it could indicate the motor’s internal thermal overload is opening and then resetting once the motor cools down.
No motor overheat and once stopped it stays stopped.
Thanks for checking! That helps narrow things down quite a bit.
Since the motor isn’t overheating and doesn’t restart after sitting, I’m less suspicious of the motor’s thermal overload.
What really stands out on your Frigidaire 417.41142000 is that the motor goes completely silent during Spin, but the control continues clicking. You also mentioned that removing the belt allows the motor to run and the cycle to continue.
That leaves us with three main possibilities:
  1. Weak motor or motor control issue: The motor may operate without a load but fail when it has to turn the tub.
  2. Excessive mechanical resistance: A worn tub bearing can create drag without noticeable shaft play.
  3. Motor wiring or connection problem: A loose connection could interrupt power to the motor, particularly when vibration increases during Spin.
Here’s what I’d check next
I’d concentrate on determining whether the motor is losing power when it stops.
With the washer unplugged, inspect the motor wiring connector for loose terminals, discoloration, or signs of overheating.
If you’re comfortable using a multimeter, the next step would be checking the motor supply voltage when it stops. This involves live electrical testing, so use the wiring diagram to identify the correct connections and avoid exposed moving parts.
  • Voltage remains present: Suspect the motor or its associated starting circuitry, depending on the motor design.
  • Voltage disappears: Look toward the motor control, wiring, or a safety-switch interruption.
One important question
When you remove the belt and run the washer through Spin, does the motor continue running normally all the way through the cycle, or does it eventually stop and start clicking just as it does with the belt installed?
That comparison will help us decide whether to concentrate on the motor and its control or investigate a mechanical load problem before spending money on parts.
I didn’t do exactly that but did remove the load when originally occurred with no movement change.
Thanks for clarifying! That’s actually helpful information. Since removing the laundry load didn’t make any difference, we can pretty much rule out an overloaded washer as the cause.
On your Kenmore washer model 417.41142000, I’m leaning more toward a problem with the drive motor or its electrical supply, especially since you’ve mentioned that the control continues clicking after the motor stops.
Here’s what I’d check next:
1. Check the motor when it stops. When the washer quits spinning, listen for any humming or buzzing. You’ve mentioned the motor goes completely silent, which makes an electrical issue more likely than a mechanical overload.
2. Check voltage to the motor. If you’re comfortable using a multimeter, check whether the motor is receiving its required voltage when it stops. The correct terminals and voltage depend on the wiring diagram. Be careful, since this involves live electricity.
  • Voltage present but no movement: Suspect the motor or its internal protection.
  • Voltage missing: Look toward the motor control, wiring, or an interrupted safety circuit.
3. Inspect the motor wiring and connectors. Look for loose connections, overheated terminals, or damaged wires, particularly around the motor.
One thing that stands out is that the washer continues operating with the belt removed. That suggests the additional mechanical load may be contributing to the failure, even though the motor doesn’t appear to overheat.
Before replacing anything, I’d like to narrow this down with one question:
When the washer stops spinning with the belt installed, does the motor start running again if you remove the belt and restart the cycle, or does it remain completely dead?
That distinction will help us determine whether we’re dealing with a motor that fails under load or a control issue that’s cutting power to it.
In Spin. Tub fills, empties, spins to completion, fills again. does not spin but pumps out water, no humming only irregular clicking, cycle continues after removal of belt, manual test of drum and motor, replace belt, cycle completes.
Thanks for the detailed update! That sequence really helps narrow things down on your Kenmore washer, model 417.41142000.
The fact that the washer completes one spin, fills again, drains, but then refuses to spin until you’ve removed the belt is an important clue.
Here’s what stands out:
  • The motor can operate normally and complete a spin.
  • The drain pump continues working when the motor stops.
  • There’s no humming, just irregular clicking.
  • Removing the belt allows the cycle to continue.
  • After manually checking the drum and motor and reinstalling the belt, the washer completes the cycle.
I’m now leaning toward an intermittent motor or motor-control problem that appears when the motor is under load. However, we still need to determine whether the motor is losing electrical power or failing to respond when power is supplied.
1. Inspect the motor connections. Unplug the washer and check the motor connector and wiring harness for loose contacts, discoloration, or signs of overheating.
2. Check the motor-control diagnostic indicators. If this washer has an indicator light on its motor-control board, observe its behavior when the motor stops. The service information can help interpret any flashing pattern.
3. Check motor power during the failure. Using the wiring diagram and appropriate live-voltage precautions, determine whether the motor control is still supplying the motor when it refuses to turn. This is the most useful test before purchasing parts.
One question that could settle this
When the washer fails to spin the second time, have you tried simply unplugging the washer for several minutes and restarting it without removing the belt?
If it starts working again after a reset, that would point more toward an intermittent electrical or control issue. If removing the belt is consistently what restores operation, I’d focus more closely on the motor’s ability to operate under load.
At this point, I wouldn’t replace the motor or control board until we establish which one is responsible.
