Sticks in same spot on the wash cycle, have replaced the temp. t-stat and the timer. Still doing the same thing. Please help is you can:mad:
Your dishwasher heats the water to the proper temperature (about 140°F) and the timer is paused during this heating process. If incoming water temperature is much bellow 120°F (recommended by the manufacturer) it could take very long time.
There is also a temperature boost t-stat that controls the timer. It isn’t the the little round one in the back that is inline with the heater. Its a 4 terminal one on the under right side. Its a common failure with this model for I have come across it a few times.
For some odd reason this temp. boost t-stat isn’t shown on the parts diagram either. I’ll see if i can find a part number for you.
