Starts and turns off quickly
I have the Maytag Quietseries 300 unit. This dishwasher never gave me problems until earlier this year and then started. When I would press normal wash or whichever setting made it light up, it would start making noise (spraying or soaking the dishes I assume) and then kick off before getting to the next stage. This didn’t happen all of the time, but started occurring more frequently as time went on. I looked at these forums and got really excited that it must be the latch assembly, so I purchased the piece and installed it myself. That did not do the trick. I can only assume that it is the control panel. The door seems to shut fine. I can’t see any broken tabs inside. Can anyone comment about the control panel? It’s about another $100 to invest into this thing that may just need to be thrown in the dump.
Thanks! :slight_smile:
Replacement parts for MAYTAG MDB7650AWQ Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet and manual
http://www.servicematters.com/maytag_library/docs/16023212.pdf
http://www.servicematters.com/maytag_library/docs/16021814.pdf
Could be that the motor is overheating and tripping it’s internal thermal protect. Check that the armature rotates easily. Open the pump up and check for debris in the chopper and impeller.
