Start/cancel button not working on maytag 100 series
All the other lights are working but the start/cancel button, which is unresponsive, so I can’t run the machine. Will replacing the control panel and touch pad solve the problem?
Replacement parts for MAYTAG MDB5600AWW Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/16023063.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/16021814.pdf
The usual way to trouble shoot this is to check the switches on the control panel (keypad) with a meter, see the tech switch. If OK then the control board is probably the problem
You may want to try the following:
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
