Start Button will not work
I replaced the door latch. the machine will not start the auto clean button lights, the cycles do not light and the options will light. On/off and delay do not work. Should I replace the door switches or the control panel? The new door latch works fine.
Replacement parts for MAYTAG MDB9750AWS Dishwasher - Undercounter | AppliancePartsPros.com
And a tech sheet and manual
http://www.servicematters.com/maytag_library/docs/16026391.pdf
http://www.servicematters.com/maytag_library/docs/16022783.pdf
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
If that does nothing check the keypad switches with a meter, see the tech sheet
