Squeeky dryer
Is it difficult to fix the squeek on my dryer. Is it possibly a bearing needing to be replaced?
Replacement parts for MAYTAG MDE6000AYW Dryer - Ele | AppliancePartsPros.com
[COLOR=“Blue”]Is it difficult to fix the squeek on my dryer.[/COLOR]
Cannot say depends on what you feel is difficult.
It will be several hours of work.
Finding the cause is often harder that fixing it.
[COLOR=“Blue”]
Is it possibly a bearing needing to be replaced?[/COLOR]
Try to get the general location of where the squeak originates before opening it up..
It can be a number of things: front glides, rear support rollers, idler wheel, motor bearings.
You will have to open it up and check these for slop/wear.
Might as well also check the belt etc., do an overhaul while you have it opened up.
Give the interior a good cleaning, including the blower wheel.
Also a good time to check/clean you vent system
Here is a manual for this series of dryer which should be useful.
http://www.servicematters.com/maytag_library/docs/16023110.pdf
And here is a good site for basic dryer repair help
http://www.applianceaid.com/dryers.html
