Squeeky agitator
When agitating, the machine squeeks at the moment it changes direction. It sounds like either a belt or plastic part rubbing and/or losing grip. I can cause it to repeat this when I have the top off and manually move the drum. However, I have not found an actual belt on the machine and do not know how to take the agitator off to check further. Does anyone know where a manual canbe found… or the solution?
thanks much…
Bill McGuire
If you have the top off, remove the front panel as well and you can see under the tub.
nat
Thanks for the info…
I had the front off and did notice a thick rubber bushing that the tub went through. I used a silicone spray on it and th noise has subsided. I’ll spray it a couple more times to see it it disappears…
Thanks again…
